96 SP not chraging and no beep - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 08-29-2011, 09:59 AM   #1 (permalink)
Default 96 SP not chraging and no beep
My 96 SP is not charging the battery. I am not sure how to start trouble shooting this problem. I am assuming it's a PMG with a recetifier. I haven't checked any fuses yet, I am picking it up today to start figuring it out.
On another note: it doesn't beep nor has it ever made a beep when installing the safety lanyard. Now here is the strange part; I was riding it yesterday and came in after cruising for 30 mins + and when I idle down (mine idles slow) I started hearing a beep trying to beep continous. reading about this sounds like an over heat condition. Then when I rev it up just a little the beep stops. Could it be I just have the idle set too low? Water surface temp is 80F and both pee'ers are peeing although not much at idle. Before this I didn't think it had a beeper, now I wonder if it should be beeping when I put the lanyard on.
Other than that this thing runs like new.
Cameron351 is offline   Reply With Quote
Old 08-29-2011, 12:44 PM   #2 (permalink)
Update: Ok, I just pulled it from the water and I checked both fuses and they are both good. There was some signs of moisture in the electrical box but not much. I also tested the beeper my temporarily shorting the temp sensor wire and the beeper works very well, it never came on that solid while it was running; I am thinking I just need to idle it up at lease in warm water.
Still not sure what I should check on the charging issue or if my ski should beep when you install the lanyard.
Old 08-29-2011, 06:07 PM   #3 (permalink)
2nd update; my charge coil is measuring 500k ohms, so that answers my charging problem.
Does anyone have a 96' SP that beeps when the lanyard is plugged in?
