'97 motor into a '93 - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 01-04-2012, 05:12 PM   #1 (permalink)
Default '97 motor into a '93
What would be involved in putting a 1997 motor into a 1993? The '97 motor is complete with bed plate and exhaust.
I know the "swap points" are '93 to '96 and '97 to '99 but I was wondering if it's at all possible. Looks like I can buy the already rebuilt '97 for less than it would cost to rebuild the '93.
Thanks,
Gerald
phorce1 is offline   Reply With Quote
Old 01-05-2012, 03:15 AM   #2 (permalink)
98yota's Avatar
Welcome to the forum! What make and model ski are you asking about?
1993 Yamaha WaveBlaster 701
1989 Yamaha WaveJammer 500
Old 01-05-2012, 06:01 AM   #3 (permalink)
1993 Arctic Cat TigerShark hull. I may have a 1997 TigerShark engine available but if the swap would be too involved I'll look harder at a top end rebuild on the 1993 engine (hole in piston, partly disassembled by P.O. then left to sit so there's surface rust in the sleeve now).
Old 01-05-2012, 06:42 AM   #4 (permalink)
98yota's Avatar
What hulls are they? What engines are being swapped?
Old 01-05-2012, 10:09 AM   #5 (permalink)
Didn't I just answer that? 1993 Tigershark hull. 1997 Tigershark motor. Is there other info needed? I'm new to PWC ownership.
Old 01-05-2012, 05:57 PM   #6 (permalink)
98yota's Avatar
Sharks have models just like cars. Toyota has Tundra, Shark has Monte Carlo etc... They came with 4 different engine sizes available.
Old 01-05-2012, 11:05 PM   #7 (permalink)
So, if you have a Montego with 640 engine, th 97 640 will fit. You will simply have to change the coupling on the rear of the crank. I just put a 97 in a 95. The other thing is that you will need the tubes that go down into the gas tank, and they are inexpensive
jefflong is offline   Reply With Quote
Old 01-05-2012, 11:10 PM   #8 (permalink)
All it has on it is "TigerShark" How does one identify the model? The hull number is ARJ00980 C393. I have the title and the last state registration paperwork but they all just say TigerShark
Old 01-05-2012, 11:44 PM   #9 (permalink)
Cant help you there, but Im sure if you have a 640 engine ( 1 carb) then you should be fine. if it's a 770, I cant help you. I have 5 sharks and all 640s
Old 01-06-2012, 12:01 AM   #10 (permalink)
Just looked, single carb. So, just the PTO coupler needs to be changed? I thought that's what prevented the later engines from swapping in, a different crank end diameter that wouldn't accept the earlier PTO coupler.
Wish I could look at two side-by-side before spending money on the motor I have lined up. yuck. ;-)
