Wait, so you can see the driveshaft turning and visually verify that the impeller is not or are you just assuming the impeller isn't spinning because the ski isn't moving?
If the impeller is actually not spinning but the driveshaft is, then there are really only two possible causes. Either the splines are damaged at the impeller or the driveshaft is broken. It's more likely that the splines are damaged or for some reason not engaged.
Pull the jetpump off and have a look at things.
