1994...help. - Page 5 - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 06-06-2012, 05:20 PM   #41 (permalink)
Watershark's Avatar
it just helps to keep the larger debris out of the water passages i would say yes but you don't have to have it. here's what my 95 calls for
Watershark is offline   Reply With Quote
Old 06-09-2012, 05:42 AM   #42 (permalink)
Josh.O's Avatar
yeah i don't think im going to get one. im getting really close to being able to crank her up[. just need a new battery, fuel filters, tank of gas and a tank of oil. after that im going to patch the hole in the bottom.
im pretty excited
EDIT: you think this would work for the oil filter? http://www.ebay.com/itm/Universal-Wa...ht_1226wt_1037
its a heck of alot cheaper than then one on that site you showed me and im a little low on money right now.
"A simple plan for life is change"
Josh.O is offline   Reply With Quote
Old 06-09-2012, 09:12 PM   #43 (permalink)
Watershark's Avatar
sure it will
Old 06-11-2012, 09:18 PM   #44 (permalink)
Josh.O's Avatar
Going to try and crank it this weekend on land. is there anything else i should do before i try?
i just don't want to leave something simple out and it wind up costing me a buttload of pain because i didn't do it.
Old 06-12-2012, 11:50 AM   #45 (permalink)
Josh.O's Avatar
should i put oil in the magneto case? if so what kind? im just worried about messing something up..
Old 06-12-2012, 03:54 PM   #46 (permalink)
Watershark's Avatar
no, it's dry
Old 06-13-2012, 04:35 PM   #47 (permalink)
Josh.O's Avatar
Okay, do you think i can use epoxy puddy to fix the hole in my hull? the hole isnt very big and i can run the ski on the water as long as i pump out the water every so often. also can i use the puddy to fill some of the scratches on the bottom? because there are a few that are kind of deep.
thanks in advance.
Old 06-13-2012, 11:13 PM   #48 (permalink)
Watershark's Avatar
fiberglass and epoxy for big holes and just the fiberglass resin for the scratches. Just my opinion. ask around there may be a better was as I am use to aluminum fishing boats.
By the way the plug on the front of the engine that "looks" like an oil plug is to check ignition timing like a car no mechanical parts in there.
