Lucky thing I dropped a bolt in my carb!!
Thanks for the help! Bolt was right at the reed valves, no problem, found a broken reed valve while in there. Lucky thing I dropped a bolt down my carb!! Betcha never heard that before. Replaced the broken reed valves, machine still wont run on its own... fuel problem I suspect, Got good spark and runs on ether or gas poured in carb, How do i determine if pump is moving any fuel? I suspect it may be clogged, dirty, damaged etc. filter seems clear and line and filter in tank are in good shape.
