Tigershark 1000 rebuild w/ Bore kit - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 03-11-2008, 09:46 PM   #1 (permalink)
Default Tigershark 1000 rebuild w/ Bore kit
Soooo, here is the deal. Ive been threw 2 1000s. well kinda three, but i bought one ended up blowing it up, bought another one and stole some parts from the first one and blew it up. then combined all the parts to make a third not so good one and that one did not last long.
So here now i want to rebuild one the right way and give it some powwwwer.
so here is what i want to do:
i have std pistons in there and want to go to the oversized 85mm pistons. but that requires alot of work but think it would be worth it, i also want to completly rebuild the carbs or maby even get bigger ones. New reeds, along with an impeller.
Now to do the oversized 85mm kit i will use wiseco pistons. I read somewhere that to do this i need to bore it out, then weld in the iner o ring slot and machine a new o ring slot farther out and machine it all flat.
Anyone know if this is needed?
Also anyone rebuilt a TS? or did a big bore kit? anything will help
clif is offline   Reply With Quote
Old 05-18-2008, 04:04 AM   #2 (permalink)
looking for engine to rebuild or cylinders and heads if you would like to part with some bitd
hardfast is offline   Reply With Quote
Old 05-18-2008, 01:57 PM   #3 (permalink)
i got a whole another jetski, what parts are you looking for?
Old 05-19-2008, 04:50 AM   #4 (permalink)
3 cylinders and crank
Old 05-19-2008, 01:30 PM   #5 (permalink)
i do have those parts, but you should know that these were out of a blown engine. they cylinders may not or may need to get bored out. also the crank will need some work. Let me know if your still intrested.
Old 05-19-2008, 04:31 PM   #6 (permalink)
can you give me a number i can call you on mine is 0407988628
Old 05-28-2008, 02:36 AM   #7 (permalink)
Default hardfast
could you post 3 cylinders for me please zip 4670australia please advise cost
Old 06-05-2008, 02:07 PM   #8 (permalink)
Default Blown shark 1000
Hi
I have just blown my TS1000 so any info you have on your rebuild would be great.
The middle bore bigend overheated and push a hole through the bottom of the case
Tigershark Wold is offline   Reply With Quote
Old 09-21-2008, 02:27 PM   #9 (permalink)
Default 1000 parts needed
i could use a few parts if still availibe
mikeallen3 is offline   Reply With Quote
Old 07-13-2010, 05:18 PM   #10 (permalink)
I need a crank for a 98 TS1000L
dgold047 is offline   Reply With Quote
