tigershark 1100 - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 08-17-2008, 08:17 PM   #1 (permalink)
Default tigershark 1100
hello all i need some info on the inline high pressure fuel pump on my 1100..
need to know what working pressure pump should test at it seems real weak and i have a service manual but it says nothing about testing the pump! thanks hope someone can help!!!
lilbodnar is offline   Reply With Quote
Old 08-19-2008, 09:35 AM   #2 (permalink)
I have been using a Polris service manual to work on my 1100 Tigershark and it has been helpful. The Polaris Ficht section says you should have 20-30 P.S.I. I found the service manual on this site and downloaded it. The file is a rather large PDF so it takes a while. The Ficht info you will need starts at about page 230. If you want to sell your shark or any parts please contact me.
trigly is offline   Reply With Quote
Old 08-19-2008, 01:06 PM   #3 (permalink)
Default Tigershark fuel presure
I checked the fuel presure on my Tigershark today and it went to 23 psi. As I said in previous post 20 to 30 psi should be good.
Old 08-19-2008, 07:13 PM   #4 (permalink)
yea it was running great the other day flushing it out for about 3 minutes and all of a sudden it died on me. i have strong spark and great fuel pressure but it acts like the injectors arent firing but i stuck the wires with my lite dioads and they look good so...
Old 08-30-2008, 07:36 PM   #5 (permalink)
I was able to find a way to get the error codes from the emm (ecu) without a laptop. Get a 5amp auto fuse (flat style). Attach a spade connector on each of the fuse terminals. Place a paper clip in the other end of the spade connector and crimp it. Cut the paper clip so about one inch of it sticks out. Use the rest of the paper clip to do the other spade connector. This is your jumper wire. Disconnect the eight pin connector from the emm. This will be the lower connector on the back end of the emm. Use the jumper to jump from the white/red terminal to the white terminal on the wire harness side (8 pin conn). Using the lanyard wrist strap, or some other method, hold the throtle wide open. Put the lanyard into the tether switch. Press and hold the bilge pump switch on handle bar. The check engine lite will start to send the error codes. If the bilge pump button is released the emm should quit sending codes. The codes are two digit codes so you will have to figure out what the light is telling you. If you can get the codes I can tell you what they mean.
Old 01-11-2012, 11:16 PM   #6 (permalink)
does it have to be a 5 amp fuse?? or can it be of more?
freddys89 is offline   Reply With Quote
Old 01-11-2012, 11:35 PM   #7 (permalink)
98yota's Avatar
Use a 5 amp fuse. More current will cause damage.
1993 Yamaha WaveBlaster 701
1989 Yamaha WaveJammer 500
Old 01-11-2012, 11:37 PM   #8 (permalink)
oh i c. thanks ima check that tommorow see if i get the fuel pump malfunction code.
