Hi
If your speedos not working check the black plastic fin thats just inside the inlet grate is not blocked & in line with the center of the ski,if its a few degrees out gauge will not work.
Also you can test the gauge by attaching a footpump to the pipe that comes off the top of the plastic fin (under the prop shaft),I have found that 1 mph= about 1 psi pressure
Hope this helps
