Old 08-20-2008, 07:37 PM   #1 (permalink)
jworden744
Default 98 TSR Runs bad
I have a 1998 TSR 1000. Ran fine until starter froze. After replacing the starter (for the fifth time since I've owned it), it ran on the trailer. Sounded OK. Once in the water, it was way down on power, wouldn't even plane out. Seemed as if it hitting all three cylinders, but no power. I put it on the houseboat, changed plugs, and started it. I noticed an inordinate amount of oil out of the exhaust. Took it home and removed all carbs and reed assemblies. They all look fine. Compression check yielded 95-100 psi per hole. Any thoughts???
jworden744 is offline   Reply With Quote
Old 08-25-2008, 11:05 PM   #2 (permalink)
JUST-IN-TIME
JUST-IN-TIME's Avatar
rebuild the carbs
TRUE JACKASS FISHING REPORTS
Old 10-22-2008, 11:19 PM   #3 (permalink)
jworden744
Wasn't Carbs. Was told that 100 times. Turned out to be the flywheel. It had so much crap built up on it that the trigger bands were throwing wrong signal to pickup... i.e. timing way off. Removed flywheel and cleaned entire flywheel and stator, ran like a champ.
Old 10-23-2008, 12:07 AM   #4 (permalink)
JUST-IN-TIME
sounds like u had water in there
always good to rebuild carbs
vB code is On
