Tigershark Monte Carlo: Replace Engine Coupler - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 09-02-2008, 09:41 AM   #1 (permalink)
Default Tigershark Monte Carlo: Replace Engine Coupler
Hi guys,
Anyone recommend the best approach to take on replacing an stripped out engine /drive coupler on a Monte Carlo? Think its a `95. Should I remove the pump impleller/shaft to get at it? or remove the engine mounts and move the enigine forward... Sorry for the ignorance - but im used to kawasaki/yamaha's any help/hints/tips/pointers would be greatly appreciated. Looking for the easiest method... Thanks...
ej_08 is offline   Reply With Quote
Old 09-04-2008, 02:10 AM   #2 (permalink)
JUST-IN-TIME's Avatar
engine needs to come out
TRUE JACKASS FISHING REPORTS
HUMAN BUILT = HUMAN FIXED
Old 09-05-2008, 12:13 PM   #3 (permalink)
I did it the opposite way. On my '96 Monte Carlo, I pulled the pump, driveshaft, removed the back plug; put a chunk of rope into the cyclinder hole to hold the piston in place while I wrenched off the coupler.
2Sharks2playwit is offline   Reply With Quote
Old 09-06-2008, 12:38 AM   #4 (permalink)
that works!
Old 09-07-2008, 04:58 AM   #5 (permalink)
Thanks for the suggestions. I took the engine route - accually easier than I thought it'd be. Just needed a long extention for the engine mount bolts (between/below the exhaust manifold), and a buddy to keep track of the shims and to help with moving the engine forward enough to get in the new coupler. Then lining it all back up and putting the shims back in place and bolts back in...
Bout a 1 hr job...
Thanks.
