Tigershark 640 crank/no start... - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 04-09-2009, 05:04 PM   #1 (permalink)
Default Tigershark 640 crank/no start...
I'm new here and new to jetski's and two strokes, but I've got a pretty good automotive background, anyways I just bought a 94 tigershark 640 for basically pennies(it sat for two years). I got it home, pulled the plugs, and turned it over and a good amount of water sprayed out of the forward cylinder. The rear cylinder had no water in it at all. I checked for spark, it was good, put some fuel in it, and cleaned the plugs. I turned it over again with the plugs out and it is still spraying a little mist of water out of the front cylinder but the rear cylinder is fine. Then, I did a compression test, 150 lbs on the front cylinder, 140 on the rear. When I try and start it, I can hear one cylinder fire a few times, but it won't start. Any ideas appriciated...
chucknorris is offline   Reply With Quote
Old 04-10-2009, 12:27 AM   #2 (permalink)
JUST-IN-TIME's Avatar
that motor is history!
sounds like a headgasket or cracked block
TRUE JACKASS FISHING REPORTS
HUMAN BUILT = HUMAN FIXED
Old 04-10-2009, 05:36 AM   #3 (permalink)
If it were a head gasket or a cracked block then would it still have 150 lbs of compression?
Old 04-11-2009, 03:45 PM   #4 (permalink)
anyone else have any input?
Old 04-24-2009, 03:35 AM   #5 (permalink)
Default 640 Crank no Start
Hi Chucknorris. I am new to this forum. Lifetime Mech. Did you get it running yet? I'll check back to see if you still need help.
Get wet, have fun.
99 640 TS is offline   Reply With Quote
Old 06-07-2009, 07:21 PM   #6 (permalink)
No actually I havn't really worked on it since I did the compression check...
Old 06-07-2009, 08:49 PM   #7 (permalink)
JayDawg's Avatar
If the motor sat with water in it for 2 years, it is toast! If the block is in solid shape you can rebuild it but I'm betting all of the internals are rusted and junk.
1996 Kawasaki 750 SXI
1999 Kawasaki Ultra 150
www.quadsforchrist.net
Old 06-21-2009, 04:29 PM   #8 (permalink)
dont sound good but i cant see it having water in ther for 2 years or it would most likley be seized or stuck by now id try getting it dryed out put a bit of oil down each plug hole turn it over a few times, get new plugs give it a little prime down the carbs make sure its fireing good put the plugs in an give it a try with that kind of compression if all else is ok it should start an run.
blasty is offline   Reply With Quote
Old 07-26-2009, 01:12 PM   #9 (permalink)
i had the same problem , it was the exhaust gasket leaking into cylinders,,
furio11 is offline   Reply With Quote
