1996 900 - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 05-21-2009, 12:36 AM   #1 (permalink)
Default 1996 900
I found a 1996 Tigershark with a 900cc motor. The guy says he fogged the engine and it has been sitting out in the elements for the past 2 years since. We get a lot of rain and moderate snow in the winter.
The thing is filthy and there is rain water inside the hull.
I can pick it up for $450. Is it worth it? If I do get it, where do I begin to get it running?
I will drain the gas first and put new spark plugs in it. Do you think it would be safe enough to hook up a new battery and turn it over to test compression without doing anything else first?
I will probably suck out the little bit of water and debris from the hull with the shop-vac and do a thorough cleaning on the outside.
I figure the trailer it sits on is worth something, so even if the ski is shot, I can sell the trailer and get a little money back.
Any thoughts/ideas?
drgriffi1 is offline   Reply With Quote
Old 05-24-2009, 01:47 PM   #2 (permalink)
Wow, what a response... lol!!
Anyways, I picked it up. Cleaned up nicely.
Pulled heads off, looked good. Got new plugs put in.
Jumped it with a car battery. The battery was not hooked up to
a car, just one I had in the shop. I checked to make sure it was
fully charged before trying. The motor turns over and has 115 PSI
in each cylinder. After checking compression, I checked spark.
And guess what... there was none. None of the three coils has
spark coming out. I find it hard to believe that all three coils are bad.
Through what little informatin I found on the internet, I have concluded
that either the magneto/stator or CDI box is bad. Does that sound right?
Any info on this matter would be appreciated.
Old 07-25-2010, 05:29 PM   #3 (permalink)
I need a cylinder for a 96 900 montecarlo was wondering if you ever fixed yours or is it for sale .if not do you know where I can get parts for mine Thanks Denny 724-875-9827
dennylib is offline   Reply With Quote
Old 07-25-2010, 05:33 PM   #4 (permalink)
Does any body know where I can get a cylinder for a 1996 tigershark 900 montecarlo jet ski I will buy the whole jet ski if some one has junked one call me at 724-875-9827 Thanks Denny
