sounds like the starter bendix is frozen up. you should be able to remove it without removing the flywheel. it is possible to soak the bendix in solvent and get it working, but IS NOT recommend as this is just a temp fix if it works at all. you can get a new bendix/starter drive at any arctic cat dealer or online.
if you must remove the flywheel to take the bendix out, you need a 3 arm bolt on type puller available at most auto parts stores as a loaner
remember to put marine grease on the o-ring seal on the front of the starter, and graphite grease on the starter drive end and thrust washers.
1999 Tigershark 1100R
