99 TSLI 1100 Only starts with a jump box - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 06-30-2009, 10:59 PM   #1 (permalink)
Default 99 TSLI 1100 Only starts with a jump box
I just bought a 1100 TSLI It only will start whith a jumper box.... comp is 120 120 and 100 would that cause it not to start?
reynj072 is offline   Reply With Quote
Old 07-19-2009, 10:24 PM   #2 (permalink)
you problem is probably not comprecion is you starting system check you starter they like to wear out the coils inside starter check you battery voltage before starting and wean you atempt to start the engine if you batt voltage is 7.60 you battery is bad also check battery positive from the battery to the elecrycal box and from the selenoid to the starter and also check all your grounds
jays17pr is offline   Reply With Quote
Old 07-23-2009, 01:55 PM   #3 (permalink)
if your battery has proper voltage it may be the cables from battery to starter.
Count me IN!
"I'll try it!"
Ron
Count me IN! is offline   Reply With Quote
