Originally Posted by IpswichWhaler
I purchased a Tigershark last fall.... Daytona w/trailer. Paid next to nothing. Never ran it when I purchased it (was dirt cheap... looks excellent) Anyway... I took the ski out and put the battery in... cranked it over. Nuttin. I took the plugs out to find that there is water in the cylinders. I am new to the Jetski world... what should I look at to determine where the water is coming from? Blown gasket?
If there are just water drops on the plugs and on top of the cylinders, it could be condensation. If on the other hand, you turn the engine over with the plugs out and it is like old faithful, then there is water in the engine. Source of the water, someone ran the unit attached to a water hose without turning the engine on. Waterbox full of water, you hit your brakes and it slings the water up through the exhaust chamber into the cylinders. Or it could be a blown head gasket, base gasket or exhaust gasket.
Dave
