Maintenance and winterizing, Whats the general spring maintenance and fall winterizin
Hey noob question #3 What do I do to get my PWC ready for the winter? I plan on storing it in my shed I guess. Are they okay outside covered up in a Michigan winter? What do I do in the spring to get ready to ride? I assume its just like a snowmobile, plugs, fresh gas, clean carbs, is there anything I need to grease on a PWC? How about the impeller shaft and steering mechanism? Mine has had the oil pump plugged off to run premix, should I remove the pump and put a block off plate on? Thanks in advance for all your help!
