Help with 95 montego - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 10-03-2009, 07:14 PM   #1 (permalink)
Default Help with 95 montego
I have a 95 montego 640 that is blowing oil out of a vent on the front of the motor, under the starter. Can anyone help and tell me why. No one in my area works on these.
calex is offline   Reply With Quote
Old 11-06-2009, 06:05 PM   #2 (permalink)
I might have the same problem. Some sort of oil is slowly appearing in the bilge but I can't tell where. I'll monitor this thread to see if there are any experienced fixers of this engine.
phoenix02 is offline   Reply With Quote
Old 11-16-2009, 06:04 PM   #3 (permalink)
I just rebuilt the starter on a '95 640 and saw the same area. Since I thought it was strange I looked it up. Here's a picture under Magneto Case.
95 MONTEGO DELUXE
There is an accordion pressure bulb under there that controls the pressure in the magneto case. It looks just like the one on the impeller case. Their function is to maintain a water tight seal while allowing the air trapped in that area to heat up and expand. Without this type of relief the air would heat up and push out from around a seal, then when it cooled back down it suck in air or water.
Based on what you said, and I'm guessing here, your accordion bulb thingy has been blown off by pressure in the magneto case. The problem is there should be NO oil, gas, vapor or pressure in that area. You have pressure in the part of the case, I would guess the front crankshaft seal is leaking. But that's just a guess.
Hampton.52 is offline   Reply With Quote
