Compression question - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 06-18-2010, 07:26 PM   #1 (permalink)
Default Compression question
Does anyone kno how long to hold the starter for an accurate reading? Im peaking out at 120 in both and thats about 3 seconds of the motor turning over.
99Ts770 is offline   Reply With Quote
Old 06-18-2010, 08:57 PM   #2 (permalink)
Mine peaks at 145 psi on both, crank until your compression guage tops out. probably about 10 seconds of crank. you should also ground your removed spark plugs when cranking engine.
I also have a question for you, one of your replys to another post. The left threaded port on the Tigershark hull, does it get plugged or stay open? The hose appears to hook to front of cylinder head.
tomalt is offline   Reply With Quote
Old 06-19-2010, 09:00 AM   #3 (permalink)
I'm not exactally sure what it flows through, but I know it should be open.
