Originally Posted by dburns48081
No apparent way to create new posts...
click the new thread button in the tigershark forum
follow the oil line from the tank to the injection pump and the two from the pump the the fittings on the manifolds. see if you can find a leak. have you noticed less smoke from the exhaust? pull both spark plugs and see if they look the same,
