BANG!! rear crankcase seal
I bought this tiger shark and it just would not run right. It had power only when primed, otherwise it boged or would want to die. I have basicaly rebuilt the 97 tigershark daytona 1000 after having all sorts of problems: #2 piston burned up and i fixed, sand in the carbs??? and I cleaned, front crankcase seal blew, and I replaced (a lot of work). It started up and I shut down for one minute, when I hit the starter again, BANG, rear seal. A huge explosion from the crankcase.
Is this a CDI unit problem?? can you test them?? I need help!!!!
