the fitting on the left side of the hull should be a female thread, and water Should come out without restriction
**what do you mean by the quick couple adapter is not there?
water comes from the cylinder, through the exhaust Y into the manifold and out the big hose then out the side of the hull
your problem is with the small hose from the head to the exhaust elbow. that water is supposed to exit from the exhaust outlet.
the fitting on the exhaust elbow is a water restrictor and must be plugged with rust/debris. take it apart and clean it
let me know what you find
1999 Tigershark 1100R
