Thanks 500 Ocian Pro Slut for your response.
Where exactly are you suggesting I put my hand? I suspect you are suggesting I do this at the discharge port of the muffer right?
Is there a difference between a water box and a muffer?
Is the muffler/water box suppose to be filled with water? If so, is this the same water that discharges out the manifold? My muffler had no water in it when I removed it. Does that indicate anything?
Thanks again,
Originally Posted by 550 OCEAN PRO SLUT
start it up and put your hand over the pipes to feel for exhaust leaks
