1998 TS-L 1000 carburetor problem or reed valve? - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 07-20-2007, 10:38 AM   #1 (permalink)
fglove's Avatar
Default 1998 TS-L 1000 carburetor problem or reed valve?
Rear cylinder blows fuel out through the carburetor throat! Anyone know what could be the cause. I held my finger over the spark plug hole and it seems as though there is compression. I do not have a compression tester. My guess is bad reed valve. It runs, but it seems like it should run better, like maybe its only running on 2 cylinders.
fglove is offline   Reply With Quote
Old 07-24-2007, 04:39 PM   #2 (permalink)
almost definitely a reed valve, if it does not seal it will blow backwards through the carb
mtcompeau is offline   Reply With Quote
Old 07-26-2007, 12:48 AM   #3 (permalink)
JUST-IN-TIME's Avatar
reed yep!!!!!!!!!!!!
TRUE JACKASS FISHING REPORTS
HUMAN BUILT = HUMAN FIXED
Old 07-26-2007, 08:58 AM   #4 (permalink)
fglove's Avatar
I had already ordered reeds before the post. Just wanted someone else to confirm my diagnosis. That was definitely the problem, one of the tabs was blown back into the cage... no pieces missing... hopefully no cylinder damage. Thanks for the advice. Ski runs better, although new plugs seem to burn rich (dark brown to black)... BR8ES, does anyone know what the gap should be set at? Also, does anyone know what the procedure is for adjusting the carbs?
Old 03-21-2009, 07:53 PM   #5 (permalink)
Do the reeds need to seat tightly when there is no back pressure on them? it looks like over time they develop a slight arc that may let some fuel back through the carb when the piston moves down. I'm guessing that when the piston moves down, it happens quickly enough that it would slam the reeds shut pretty quick, but I may be wrong.
If they develop this "Arc" can they just be flipped over?
Thanks for any advice you experts out there may have on this. Can't wait for summer!
Pahchay is offline   Reply With Quote
Old 07-13-2010, 12:47 AM   #6 (permalink)
Default 1998 TS-L 1000 Reed problem
BR8ES is the wrong plug book says BR9EYA I had trouble finding them I got them at NAPA auto parts. I burned a hole in side of piston while using BR8ES
dgold047 is offline   Reply With Quote
