ok the motor part of the driveshaft has no play with the drive shaft back in and evrything put back together if i move the shaft left and right i hear the noise coming from the back
i really do think that your prop is hitting the wear ring... see if you can shake your motor by hand like see if you can moe your motor up and down and side to side.
