purging a gas tank - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 07-20-2011, 10:49 AM   #1 (permalink)
Default purging a gas tank
Whats the best way to purge a gas tank? The TS I bought had water in the carbs so a complete purge is in order. Also someone else has asked and I also need to know, whats a good drive oil to put in it? Thanks
rambo0422 is offline   Reply With Quote
Old 07-20-2011, 12:17 PM   #2 (permalink)
aaron9350's Avatar
I would carefully siphon out the tank as much as possible then disconnect the fuel supply line from the bottom of the tank or the reserve/on/off switch and siphon the rest from there. Once you get everything out remove the fuel level float if equipped and make sure all moisture is out too. also check and remove any debris if you can. replace the fuel lines if needed and the filter and ensure the carb is cleaned out with carb cleaner/WD40. Also when refilling with fuel, use Sta-Bil blue fuel stabilizer with ethanol treatment.
I have a container of drive oil I do not need that I bought for my 1996 Montego but it is since long gone and my other ones don't use drive oil. Pay for shipping and it is yours.
1998 TS1000R, stock; 1999 TS770, Solas impeller
aaron9350 is offline   Reply With Quote
Old 07-20-2011, 12:58 PM   #3 (permalink)
Be glad to paypal it to you or mail you a check, your chioce. Let me know how much to mail to flatwoods kentucky. Thanks
Old 07-20-2011, 09:05 PM   #4 (permalink)
aaron9350's Avatar
I will take Paypal, money order, cashier's check. Paypal is quicker though. You can send $6.50 for shipping USPS to 41139 if that zip is correct. My e mail associated with the Paypal is aaron9350@live.com and send a good ship to address too. If you want to mail the money order, I will PM you my address. Here's a pic of the bottle that has not been opened to make sure it is what you need. Aaron
Old 07-21-2011, 04:24 AM   #5 (permalink)
Default Paypal sent
Hey AAron I sent you a Paypal for $6.50. Thanks for your help with this matter and my address is James Adkins 1404 Christopher Ct. Flatwoods Ky 41139
Old 07-21-2011, 09:08 AM   #6 (permalink)
aaron9350's Avatar
Thanks, got the money and will send it out. Aaron
Old 07-22-2011, 01:28 AM   #7 (permalink)
aaron9350's Avatar
Drive Lube has been shipped USPS and should be there Mon. Aaron
Old 07-22-2011, 05:51 AM   #8 (permalink)
Default Oil Shipped
Thanks again Aaron.... You've been a great help. Some time later on though I will have to find a good substitute oil that can be easily obtained.
Old 07-22-2011, 11:07 AM   #9 (permalink)
aaron9350's Avatar
Not a problem.
