96 Montego Oil Leak
I recently purchased two identical 96 Montego's Both in excellent condition with two previous owners who had them maintained. I've had them on the water about a dozen time this summer and have noticed some oil and water in the hull and finally decided to give them a good cleaning.
1st- I did a flush, the correct way! for about 5mins for each ski.
2nd- I pulled one at a time off the back of the trailer at an incline so water would drain. so I sprayed engine degreaser and power wash the inside until they shined.
When finishing up the second one I fired it up so the bilge pump would pump out some of the water then I noticed oil leaking off the engine mount plate.
I tried to see where it was coming from and it looked like it was dripping near the front of the starter but not sure of the exact source.
I'm not sure if it was like that prior to the wash and just didn't notice because they were dirty to begin with or if it was a result of being on the incline.
The oil was clean and blue in color, so I'm wondering if I have a bad gasket somewhere or something else.
These are my first ski's so I don't know too much about them, but have learned quite a bit and am capable of doing repairs.
Thanks! Chris
