550sx will only run for 10 min - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 11-18-2011, 04:12 PM   #1 (permalink)
Default 550sx will only run for 10 min
ok so this has happened to me 2 times now.. i have a 1990 550sx with the waterbox taken out and that is the only mod done to it..... i ride it in the ocean.. it idles and runs fine in the harbor, but when i start riding it in the ocean it bogs, shuts off, and wont start.... i tow it in and get it home.. it starts after at least a minute of cranking over and a whole lot of starter fluid..
any help would be great,
thanks
tdub is offline   Reply With Quote
Old 01-02-2012, 11:48 PM   #2 (permalink)
98yota's Avatar
I would put the water box back in, it is a baffle that not only keeps water from entering the exhaust from the outside it also gives necessary back pressure. 2 strokes need back pressure to run right.
1993 Yamaha WaveBlaster 701
1989 Yamaha WaveJammer 500
Old 01-02-2012, 11:51 PM   #3 (permalink)
98yota's Avatar
I would also rebuild the carb and give it a good cleaning.
Old 02-06-2012, 10:52 PM   #4 (permalink)
thanks. ill give er a shot
Old 02-07-2012, 01:17 AM   #5 (permalink)
p10sdad's Avatar
Stay away from starter fluid also. Thats a great way to seize your motor
Old 02-14-2012, 12:19 PM   #6 (permalink)
98yota's Avatar
Using a squirt bottle with pre mix is the way to go.
