Originally Posted by goldfish
So what happens if you do put oil in that plug? The guy I got my skis from said that he ran amsoil in them... and if there is no oil that should sit in the crank of an 86 550, would you really mix amsoil with the gas?
Yes if he has eliminated the oil injection pump you would have to PRE-MIX your gasoline with a 2-STROKE oil. He was refering to using Amsoil as the pre-mix oil he always used. If you don't pre-mix you will run for about 2 minutes before you seize the motor. If the injection pump is still intact then there will be an oil reservoir tank that you have to fill.
Don't put oil in the little hole. These are not oil bath ignition systems. I'm not sure what kind of damage will happen, but it won't be good!
