Js550 Vs Ks550 Sx - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 09-02-2008, 06:09 PM   #1 (permalink)
Default Js550 Vs Js550 Sx
can someone tell me what the difference is between the reg. JS550 and the JS550 SX?
i believe in 1990 they started with the SX. My ski is a 1989 JS 550.
i have the manual for the SX and it look the same when i match things up as far as looks go.
also my ski is stock except for R&D intake grate and a ocean pro ride plate.
i looking to do some light mods on a budget and also keep it relayable.
i am looking for lower to mid range power.
kawikdogg7 is offline   Reply With Quote
Old 09-02-2008, 07:28 PM   #2 (permalink)
JUST-IN-TIME's Avatar
pre sx is a piston port no reeds
sx ski has reeds
TRUE JACKASS FISHING REPORTS
HUMAN BUILT = HUMAN FIXED
Old 09-04-2008, 05:44 AM   #3 (permalink)
jonesy54's Avatar
i think the SX has a different impeller/pump also.
-1990 X-2 - the weird one
Old 09-04-2008, 06:01 AM   #4 (permalink)
same pump different shaft and impeller
Old 09-04-2008, 06:21 AM   #5 (permalink)
jonesy54's Avatar
ok, i knew the impeller was different, i guess i just assumed the pump was also.
Old 09-04-2008, 07:23 PM   #6 (permalink)
yep ones like 7 splined the other is like 15 splied
u could use any 440/550 shaft just need the right impeller
now if u go with a 440 pump, u get better thrust
Old 10-01-2008, 01:50 PM   #7 (permalink)
'90 sx is not a reed motor, '91 sx is the first reed motor, other info above is correct
mike84c is offline   Reply With Quote
