550 sx Electrical problem - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 10-14-2008, 02:04 AM   #1 (permalink)
Unhappy 550 sx Electrical problem
Hi,
I have a 550sx thats been stored for a while in my shed. I remember fireing it up about 6 months ago, apart from the carb needing a rebuild it was fine. My SJ is in for a rebuild so i wanted something to muck about on until its done.
Ok, so i charged up a good battery and went to fire it up and what i got is just a clicking in the electrical box. Cleaned up all the lead and terminals and still nothing but the clicking. I then swapped the starter button with a spare to test that and no different. Next i swapped the magnetic switch over with a spare again no difference. I then swapped all the leads i.e. battery earth, battery live and starter lead with new. No difference. Then swapped the voltage regulator & stop switch relay. Again nothing. The starter is brand new and still under warranty so im sure its not that.
Starting to get more than a little frustrated. Has anyone got any other suggestions as to what to try????? Please??????
Just thought i would add that the stater is out and i can turn the engine over by hand.
dcjetski is offline   Reply With Quote
Old 10-15-2008, 01:02 PM   #2 (permalink)
You've done a lot of things, most of them good ideas. I would put the starter back in, pull the plugs, and take the red lead off of the starter, extend it with a jumper to the pos. terminal of the battery. just tap it, the starter should fire over the motor with the plugs out. If this works, I would check the starter solenoid, but you already swapped that. I wouldn't bother with the start stop switch, since you heard the solenoid clicking when you pressed it, its good. with all the extra parts you have you should find the problem.
mike84c is offline   Reply With Quote
