js440 spark problem - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 02-05-2007, 03:25 AM   #1 (permalink)
ridekawa's Avatar
Unhappy js440 spark problem
got little or no spark on both plugs ,does this sound like a coil problem cos bad stator would probably work on one plug If someone can email me a wiring diagram I would also be much abliged
cheers
ridekawa is offline   Reply With Quote
Old 02-05-2007, 01:08 PM   #2 (permalink)
JUST-IN-TIME's Avatar
u will need a manual to determine what is wrong
it could be stator or the coil
TRUE JACKASS FISHING REPORTS
HUMAN BUILT = HUMAN FIXED
Old 02-05-2007, 03:02 PM   #3 (permalink)
ridekawa's Avatar
thanks ocean, I will have to bite the bullet and get a manuel (am a little reluctant to use credit card over net)
Old 02-05-2007, 03:05 PM   #4 (permalink)
try marineengines
or amazon, brnes and Noble
u can get hem at the local bookstore or even the library
Old 02-06-2007, 02:07 AM   #5 (permalink)
ridekawa's Avatar
am "down under"but even so the libary may be of some help till i get a manual
tonight i am going to put a test light on the wires from stator to coil and crank it over
I guess if i get a pulse then its the coil
Old 02-07-2007, 01:46 AM   #6 (permalink)
ridekawa's Avatar
took off flywheel and after a little bit of probing with a test light and a soldering iron all now seems right with the world again
cheers
