js550 new motor won't start help - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 06-29-2009, 04:48 PM   #1 (permalink)
Default js550 new motor won't start help
i bought a js550 with a fully rebuilt motor had a broken starter so i didn't see it run. it started for 1 sec then died it sounds like it wants to start but doesn't. has great compression, spark, tried starter fluid no idea. any help or ideas would be great thanks
kawi440 is offline   Reply With Quote
Old 07-02-2009, 11:31 PM   #2 (permalink)
three questions do you have spark? do you have fuel delivery? do you have compression? if you have these it will run its just a matter of tuning. once the starter is fixed crank it and check all the above and go from there
volkster67 is offline   Reply With Quote
Old 07-11-2009, 01:06 AM   #3 (permalink)
have u tried priming the fuel circut? pull the return line off the carb lightly pressurize the fuel tank and gas should bleed out the return nipple on the carb hook it back up and then try it. I have to do this on my ski before every ride cause i am too cheap to buy the aftermarket pump primer. but it works. give it full choke till it pops then 1/4 choke.
OL JS Rider is offline   Reply With Quote
Old 07-19-2009, 09:12 PM   #4 (permalink)
Check the vacuum pulse line from the crankcase, see if you've got a good bounce on your vacuum gauge. If it just sits there you've got a crankcase leak. Be very careful with the starter fluid and a leaky crankcase you can end up with a runaway engine
Scarab95 is offline   Reply With Quote
Old 07-29-2009, 06:39 PM   #5 (permalink)
Is the vacuum pulse from the crankcase what pulls the fuel from the gas tank?
rhett1366 is offline   Reply With Quote
Old 07-30-2009, 08:25 AM   #6 (permalink)
No, its the line from the crankcase to the carb. If you have a case leak there won't be a pulse. Hook up a vacuum gauge to the line and see if the needle bounces
Old 07-30-2009, 02:52 PM   #7 (permalink)
ok but what is the purpose of the pulse? and if i dont have a vacumn gauge will i be able to feel it with my finger whilei turn the engine over?
Old 07-30-2009, 03:07 PM   #8 (permalink)
Sorry, yes the pulse pulls the fuel into the carb. It will also tell you if all the crank seals are good. Even if you have fuel, spark and compression, a piston port type motor (440 550) needs a good crank seal
Old 07-30-2009, 04:30 PM   #9 (permalink)
Alright well im working on a 750ss and it has pulse vacumn to the touch but it is not pulling fuel in, but there is so many fuel lines and a whole fuel filter it needs to fill before it enters the carb, should i try to prime the fuel lines?
