650 SX impellar/pump removal - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 07-17-2009, 08:21 AM   #1 (permalink)
Default 650 SX impellar/pump removal
I have a 91 650 SX and need to remove pump and impellar assembly...any tricks? Do i just remove the 4 bolts that hold pump? I know the impellar comes out with pump....does it just slide off the shaft with the entire assembly?
any help is appreciated.
Kevin
kevjul is offline   Reply With Quote
Old 07-17-2009, 10:22 PM   #2 (permalink)
no fear here's Avatar
Yes it just slides out the back. It's a bit of a pain to do though. Cut as much of the silicone caulking away as possible before trying to gently pry the pump housing away from the hull.
Hold the driveshaft to keep it engaged with the engine while sliding the pump back or you could damage the seals at the through hull assembly.
Hope this helps
PJS Exhaust & Waterbox
38mm Keihin
R&D Reeds, Cages & Stuffers
Skat 15
R&D Toploader Scoopgrate
Ocean Pro rideplate
Pump drilled for dual cooling
500gph rule
