85 JS440 Electrical Issues - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 08-17-2009, 06:29 PM   #1 (permalink)
Default 85 JS440 Electrical Issues
This is my first post so bear with me. I have a 1985 JS440 and had a couple of the magnets fall out of the flywheel. Surprisingly, there was little damage done to the stator. I found a flywheel that had magnets in good shape and glued them into the original flywheel. I know, it probably wasn't the greatest idea, but it was a quick fix. After putting the motor back together, I have spark, compression and fuel, but no firing. Not even if I put a little gas in the cylinders. Is it possible that it isn't firing at the correct time. If so, does anyone know how to check when the plugs are firing? I haven't made any adjustments to the electrical system, and it was running fine before the magnets came unglued. Any help would be greatly appreciated. Thanks.
tomahawk256 is offline   Reply With Quote
Old 08-17-2009, 09:03 PM   #2 (permalink)
no fear here's Avatar
You need to get a replacement flywheel.
If you get the polarity wrong on the magnets it won't work.
If they are placed in the wrong spot the timing will be out.
I have seen pistons melted due to the timing being advanced too much.
Have you ran a continuity and ohms resitance test on the stator assembly?
PJS Exhaust & Waterbox
38mm Keihin
R&D Reeds, Cages & Stuffers
Skat 15
R&D Toploader Scoopgrate
Ocean Pro rideplate
Pump drilled for dual cooling
500gph rule
Old 08-17-2009, 09:34 PM   #3 (permalink)
No, I haven't put a continuity tester on it yet. Looks like I'll have to spend some cash and get a new flywheel. As long as it's producing spark, the stator should be ok, right? I thought they either did or didn't work
Old 08-17-2009, 11:28 PM   #4 (permalink)
Yeah, sorry my bad on the continuity and ohms test.
38mm Keihin
Skat 15
Ocean Pro rideplate
500gph rule
Old 08-19-2009, 11:00 PM   #5 (permalink)
How do I know to get the polarity correct on the magnets?
Old 08-20-2009, 09:44 AM   #6 (permalink)
I don't know which way they are suppose to go.
You would need a good flywheel to check it against. A magnet with north and south marked on it. Then check the good flywheel for the polarity of the magnets.
Providing you glue your magnets in the same it should work.
38mm Keihin
Skat 15
Ocean Pro rideplate
500gph rule
