JS550 not charging battery - Page 2 - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 05-31-2011, 03:27 AM   #11 (permalink)
Exclamation ok I need a little help
I know I am posting on an old thread but I am having a similar issue.
except my ski is acting like it IS running off of the battery.
I just bought a 88 JS550. Never owned one before and this past weekend I taught myself how to stand up on one... yay me. but I sure did not have it easy. I charged the battery because it was dead when I got the ski. The batt held a charge in my garage for 3 days so I figured im good to go.
I launch it in the lake and fell off about 20 times... every time I fall off the motor dies (carb was set poorly)
finally get sick of it cutting out so I go to shore and adjust the carb.
I go to do a off shore take off and 10 feet later the ski acts like it has no power and sputters to a stop. The batt is now dead and cant turn over the motor at the speed needed to start. I grab my booster pack and it fires up but when I try to take off it dies again in 10 feet.
I hook up the booster pack and have a smoke then start it... then apparently the 10 min I took to have a smoke while the booster pack charged up the batt was enough for me to get 100 yards out of the ski before sputtering to a stop
then I pull the battery and charge it over night. this morning I put it back in the ski and I rode it on the lake for about 20 min with the ski acting flawlessly. I let go of the throttle and it idles... I hit the throttle and it revs up and takes off like a bat out of hell... but after 20 min of constant running the damn thing just sputterd to a stop on me again.
it has plenty of fuel
the carb is set right.
the batt wont supply enough juice to turn over the motor (yes I know the first 2 have nothing to do with the batt)
my issue here is if the ski cant run off the batt even if it needed to...... then how is it that im running my batt down running my ski?
and with my volt meter im getting 12.5 volts off the batt when running and that number was lower and lower every time I checked it until it quit only giving 11.3 volts when it shut down the last time.
everything on my ski appears stock....
I am just bugging out looking at a $300 stator assy for a $500 ski
shoot me a few ideas ANYONE before I swill enough beers to dump waaay to much money in a ski that prolly aint worth what I am thinking of doing.
WrecK
WrecK is offline   Reply With Quote
Old 05-31-2011, 10:45 AM   #12 (permalink)
jleuck64's Avatar
Yup, it sounds like you need a new charge coil. The voltage readings you are seeing indicates there is no charge when the engine is running. I found just a charge coil online with a little research and it only cost around 30 clams if I remember correctly. No need to spend the dough on both coils if you engine will still run, just need to swap out the one that is dead.
With your battery being so deeply discharged on a lot of occasions it is likely that it has become sulfated, so you might want to budget for another one.
If you don't have a repair manual for your ski yet, I would strongly suggest you get one! It helped me a ton when trouble shooting this problem as well as everything else that I have managed to teach myself about fixing this toy
When I got the front cover off I discovered the o-ring seal was damaged, letting water in. When I got the flywheel and the coils removed I discovered the front crank seal had failed... so be prepared to find more problems, just saying!
jleuck64 is offline   Reply With Quote
Old 05-31-2011, 12:48 PM   #13 (permalink)
Default yaaaaay
Thanks for the reply...
The thing I dont get is the one guy said that the ski can run all day long with a dead batt, However... when my ski runs it drains the batt untill the batt is dead.
I just dont understand how with the 2 coils (one for charging the batt and another for providing spark) how my batt can run down while running my ski.
anyway... is there a possability that the voltage regulator in the elec box can be bad?
I have not tore down my ski yet but if anyone knows what wire I need to find to test from the coil going to the voltage regulator to make sure that power is even being sent to the regulator.. that would be helpfull.
I have rebuilt the motor in my truck... in my Harley, and in my lawn mower... but this ski is a totaly different animal....lol
Old 06-02-2011, 11:30 PM   #14 (permalink)
jleuck64's Avatar
You can ride your ski all day long when you are fresh and rested, sort of like being brand new.
When you are tired and wore out you can't ride as long before getting weak, sort of like your battery is I think
Old 06-05-2011, 06:10 AM   #15 (permalink)
Default I got it fugured out... almost
I looked at the wiring harness going from the stator (coils / magneto) and I found that the black wire (ground wire) was melted and totaly roasted. it was also completely GONE in the E-box. I did however figure out where it went in the E-box and I pulled the female pin terminal from the E-box end of the plug and created a new ground wire for the E-box internally. Then I ordered a new wiring harness to go from the E-box to the stator assy.
then once I took the stator cover off and removed the flywheel I found that the charging coil was jacked and the exciting coil under the pulsing coil was starting to fall apart as well (intermitent issue) and must have been the cause of the ski just shutting down.
yes this means that the batt was only going dead due to restarting the ski over and over again
now when I removed the wire retainer off of the stator plate (the plate the coils are mounted to) the wires shifted and most of them just fell out of there connectors.
here is my dilema.
I have the charging coil monted to the plate
I have the exciting and pulsing coil mounted to the plate
I have the brand new wiring harness set up and ready to go
I just have NO IDEA what wires from the coils get attached to the wires for the wiring harness
AND
which wire on the pulsing coil gets attached to the exciting coil
correct me if I am wrong
the red wire on the pulsing coil (the smallest coil) gets attached to the red wire on the wiring harness
the grey wire on the pulsing coil gets attached to the grey wire on the wiring harness and the two grey wires get attached to the loop coming out of the back of the exciting coil
the black wire on the wiring harness with the loop on it gets attached to the stator plate using the same screw that holds the wire retainer (the metal retainer that all of the wires get run through on the inside of the stator assy)
the 2 wires on the charging coil (on this coil they are yellow) get attached to the two green wires on the wiring harness (also assuming that it makes no differance which wire from the charging coil gets attached to either of the green wires
I could really use a picture that shows good detail of someones stator assy and would allow me to see which wires are attached to what wires from the harness.
or if it is possible to see a scan of the diagram showing this in detail from a service manual if it shows it there?
thanks in advance.... once this is done I will be back on the water falling off every 100 yards or so.
seriously.. it sux owning one of these and not being able to take it out on the lake.
Old 06-05-2011, 10:51 AM   #16 (permalink)
jleuck64's Avatar
These are like 35 clams and will really speed up your learning curve, plus reduce the new owner frustrations, trust me.
Old 06-05-2011, 12:32 PM   #17 (permalink)
Default i hear ya....but
if I could see a pic or a scanned page in the book explaining what I need to know here then I get to save that 35 bucks and boom.. im out on the water.
I will eventually get the manual. Just, its sunday and I would like to get out on the ski today
any chance you see that page in your manual?
