kawasaki jet ski????? - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 05-28-2010, 03:24 PM   #1 (permalink)
Default kawasaki jet ski?????
Hi, recently purchased a used stand up jet ski, I was told it is a 650, but wondering if there is a way to tell for sure what model it is? it has a lot of performance parts on it, pipe, ride plate, scoop, carb, air filter. I'm not sure if its worth getting it running or parting it out, either way I need to know what model it is.
thanks
GWCPWC is offline   Reply With Quote
Old 05-28-2010, 04:17 PM   #2 (permalink)
jonesy54's Avatar
A few pictures would be very useful for helping i.d. what you've got.
550s and 440s have a little manufacturers label on the engine near the drive shaft coupling. I'm not sure if 650s have that or not.
-1990 X-2 - the weird one
Old 06-01-2010, 08:20 AM   #3 (permalink)
Well, I did some research over the weekend and looked up the hin # and its an 89 Kawasaki and the side of the cylinder has .655 cast into it, so I'm assuming its a 650.
I tried hooking up a battery booster to it and I got the bilge pump to work, but when I tried to crank it, I got nothing, not even a click??? is there some kind of switch or safety? I've seen lanyards on some of the other jet skis in pictures, but this one does not have one.
Old 06-28-2010, 02:46 AM   #4 (permalink)
Just to the right of the start botton there is a knob, (starter interlock). Pull this knob out towards the right. If it is already out you will need to start testing the starter system.
Contact me: prickofmisery@verizon.net
prickofmisery is offline   Reply With Quote
Old 06-28-2010, 12:34 PM   #5 (permalink)
Yes, I tried that knob, wasnt the problem, after doing some more testing, looks like the starter relay is bad. I jumped the terminals and it cranked, shot some starting fluid in the carb and it fired right up
Old 06-28-2010, 08:12 PM   #6 (permalink)
Have you tested the start switch?
Old 06-29-2010, 07:53 AM   #7 (permalink)
No, I'm not really sure how to test it?
Old 06-29-2010, 11:46 PM   #8 (permalink)
Hook an ohm meter up to the start button wire ends in the ebox and check for continuity
