Yes it's a 2 stroke engine, got 2 classics with the same engine.
Although the
js does not have a separate container for the 2 stroke oil, instead pre-mix,, yes correct. But ehat you are saying is the gasoline mixed with the 2 stroke oil... Lubricates the roller bearings and conrods. which is ironic beacause gasoline or pre-mixed fuel enters into the chamber thus igniting the gases, but what you are saying is it also lubricates the bottom of the block.. Pls explain how does the gasoline seep through the piston rings flodding the crank thus lubricating the system which i may add is fuel/oil lubricating the bearings..it does not add up.
Again, what lubricates the crank/roller bearings?
You say the pre-mix gasoline coming from the gas tank. then there should be a line going to the crank which i don't see. Second, gasoline/oil cannot lubricate a bearing. It gioes against the laws of mechanical engineering.
Did i sound Cocky??? Yes... oh well Cheers
