Wiring / Other Questions - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 08-01-2007, 05:37 PM   #1 (permalink)
Default Wiring / Other Questions
1st off it may be helpful to figure out what year my Kawasaki Jetski is. It's a Red, White & Blue 300 Serial # KAW 45678A686
Are there any online wiring diagrams available? It can't be too tough there's only about 10 wires. It's turning over, has compression but no spark.
How do you drain the oil out of the motor? How much of what kind should I put back? Actually I'm a bit surprised to see oil in a two stroke that, as far as I know, doesn't have a transmission.
Thanks in advance.
mo650chopper is offline   Reply With Quote
Old 08-01-2007, 09:58 PM   #2 (permalink)
JUST-IN-TIME's Avatar
1986
there is no oil in the motor it is a 2 stroke
your screwed if oil is in there
no spark, you will need a meter and a dva
TRUE JACKASS FISHING REPORTS
HUMAN BUILT = HUMAN FIXED
Old 08-02-2007, 04:54 AM   #3 (permalink)
Seemed strange to me to have a dipstick on a two-stroke motor. I have meters just no diagram.
Old 08-02-2007, 10:10 AM   #4 (permalink)
that is not a dipstick
it is the timing hole plug
Old 08-02-2007, 07:59 PM   #5 (permalink)
Default Pics of dipstick / timing plug?
See attached pics. I know it shouldn't be but it sures appears to be a dipstick with oil level in the lower end. It doesn't look like a timing plug hole to me. It appears to me the timing would come from the front side of the motor. I'm also assuming this has a electronic ignition not points being it's a 86 model. Is that a correct assumption?
Wiring / Other Questions-oilfill.jpg   Wiring / Other Questions-wiring.jpg
Old 08-02-2007, 10:30 PM   #6 (permalink)
only one spark plug right
Old 08-03-2007, 04:45 AM   #7 (permalink)
Yes only one plug. The 2nd is a known good plug I was using to test for spark.
