Just above idle water comes out. Are you far from the lake? I'm guessing you tuned your ski hooked up to the garden hose! Try re-jetting at the lake. Being hooked up to a hose, and being under a full load are very different. I had 90 do the same thing. Things to check, stator, timing, carb rebuild, exhaust leaks. I would put my choke a 1/4 on and that thing ran like a champ
