Looking at a JS440 with a 550 engine swap - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
post #1 of 13 (permalink) Old 06-14-2011, 06:36 PM Thread Starter
I found a 84 JS440 with a 550 swapped in for a pretty good price. Looks and runs good. Are the JS440 the same as the JS550, just different motors? Should I be cautious of anything in particular on this ski?
carbongixxer is offline
post #2 of 13 (permalink) Old 07-01-2011, 02:35 PM
Probly too late for this but if it runs good and looks good get it. The 440 has a smaller pump but it accually helps with control and off the line speed. Its a good thing. 440 550 swaps are the way to go imo
550subman is offline
post #3 of 13 (permalink) Old 08-12-2011, 06:59 PM
jonesy54's Avatar
yeah, +1 on 550subman's comment!
440 pumps are definitely better. I have a 440 that I dropped a 550 into myself. As far as I know the pump is the only difference between the two.
-1984 JS550 clone -
, 440 pump, Skat Trak, primer, thumb throttle
-1987 JS550 - bone stock
-1985 JS550 basket case
jonesy54 is offline
post #4 of 13 (permalink) Old 10-08-2011, 08:49 AM
seadoobutch787's Avatar
If you end up putting more hp into the engine (porting) you will need a bulkhead support. The 440 pumps will stress crack the hull when they are hopped up. The 550 pumps are bolted to the frame of the hull, the 440 are not.
96 Seadoo XP limited mod
96 Seadoo GSX the cruiser
94 Kawi 750sx freestyle build in the works
seadoobutch787 is offline
post #5 of 13 (permalink) Old 12-26-2011, 09:46 PM
98yota's Avatar
The nice thing about those old JSs is there seems to be an endless supply of new and used parts! We have an 85 JS500 and it's bullet proof! Get it and have fun!
1993 Yamaha WaveBlaster 701
1989 Yamaha WaveJammer 500
98yota is offline
post #6 of 13 (permalink) Old 03-20-2012, 12:26 PM
Js 440 / 550
Im new here and have a few questions i have just go a js440 for 50 quid and the engine is knackered will a 550 fit and run off the same ignition system any help would be great...
Biscombe is offline
post #7 of 13 (permalink) Old 03-20-2012, 01:41 PM
jonesy54's Avatar
Originally Posted by Biscombe View Post
..will a 550 fit and run off the same ignition system...
absolutely. They are the same part as far as i know. I used the 440 ignition components when i did my 440-to-550 swap.
-1984 JS550 clone -
jonesy54 is offline
post #8 of 13 (permalink) Old 03-20-2012, 02:22 PM
Any other things i should be aware off as im compleatly new to this. should i stick with the original carb for a 550 or is there a better one i should look out for and the 550 motor i have my eye on is the old one with no reeds as there is nothing else around
Biscombe is offline
post #9 of 13 (permalink) Old 03-20-2012, 02:31 PM
Oh the other thing is are the bottom ends the same as the 440 i have has a good bottom end. So is it possible to fit a 550 barrel on it and head to match or even a 550 barrel the one with reeds. if i use the one with reeds do i need a different intake manifold as its at a slant cheers nigel. sorry for all the questions
Biscombe is offline
post #10 of 13 (permalink) Old 03-21-2012, 06:22 AM
jonesy54's Avatar
If your 550 comes with a carb use it unless its hosed. The 1986 and later 550s (the ones with JetPower exhaust) use a larger carb than the older ones. I have a pre-1986 550 and am using a 440 carburetor on it and it works just fine.
-1984 JS550 clone -
jonesy54 is offline
Human Verification
