Try adding Sea Foam to the your fuel. 1oz per gallon is the normal recommended amount but, for something as stubborn as you have described, try a stronger mix. Each can of Sea Foam is 16oz. It may take some time for the treatment to work but, the treatment will dissolve just about any blockage with a little time and patience. I had a similar issue with a XL1200LTD and Sea Foam cleared the problem after using about 24oz. of the product, 10 gallons of fresh 93 octane fuel, and a few days of running at various speeds. Performance improved each day after sitting approximately 24hrs. between runs. If you want to perform an extreme attack on the blockage, you can pull the fuel filter, submerge it in the Sea Foam until the filter is full, carefully re-attach the fuel lines to the filter and try to start the engine. This will inject a 100% solution Sea Foam into the jets. Try this a couple of times and let it sit for a day. If the blockage is gum or varnish, the 100% solution of Sea Foam will almost definitely dissolve it by the next day. Good luck.
