89
JS 550 basically stock with just a K&N filter and rev limiter removed.
I just rebuilt the carb and put new pop off spring in it. The pop off pressure is 11 psi which should be fine, but I read in a post you have to lower it with a K&N.
What should it be lowered to?
Also, I opened the plug on the fly wheel cover and it was pressurized... Should there be pressure in there?
B.
