Confused!! xl-1200 which engine - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 09-10-2011, 03:28 PM   #1 (permalink)
Default Confused!! xl-1200 which engine
Thinking of purchasing a xl 1200. Has year 98 on serial number (HIN) but a 2001 hull colors. It also has the power valve engine and to my knowledge a 98 has the carburated version. The engine is bad (cylinder 1 front has no compression. 2 & 3 the same (about 105 psi) Should I rebuild or can I put a carburated 1200 motor in it. Can buy for the package for $300 with a trailer. The hour meter reads 34.5 hrs. It was in storage for 5 years. Thanks.
bigbadbubble is offline   Reply With Quote
Old 09-10-2011, 06:26 PM   #2 (permalink)
YamaDoo's Avatar
That's a great deal. The trailer is worth the money by itself. Rebuild the motor and you'll practically have a new jet ski for well under $2k. Post a pic of it if you can.
I think the fuel injected came out in 2003, I know it did on the GP1300r, not very familiar with the XLTs though.
Old 09-12-2011, 01:35 AM   #3 (permalink)
Are you saying it doesn't have carbs?
Old 09-12-2011, 11:37 AM   #4 (permalink)
YamaDoo's Avatar
No, I am saying it probably does have carbs.
Old 09-12-2011, 03:21 PM   #5 (permalink)
Then just rebuild the one cylinder and you should be good to go. Try to determine why it lost one cylinder though. Weird for a ski withonly 35 hours.
Old 09-13-2011, 11:57 AM   #6 (permalink)
Letting a jet ski sit is probably the worst thing you can do for them. Plan on rebuilding all 3 cylynder, overhauling the triple carb rack, replacing the oil lines, flushing out all cooling passages, getting rid of the cat. converter, and updating powervalve clips if you want a dependable waverunner.
