1. Most common reason would be you left the drain plugs out, or they are leaking.
2. After you get as much water out as possible through the spark plug holes, you just need to ride the hell out of the ski to clear any residual moisture. I'd recommend putting some Stabil or Startron in the fuel then ride, ride, ride. Alcohol attracts moisture, but does not get rid of it. That is exactly one of the reasons ethanol fuels cause so much damage, not to mention what it does to rubber, and plastic parts. Putting alcohol in there would NOT be a good idea. After you get it home, pull the spark plugs and spray fogging oil down the cylinders, and bump the engine over. I'd do that multiple times to distribute as much oil around as possible.
3. You don't usually need to tear down the engine if you work fast to get as much water out as possible, then ride it. You may need to change out the spark plugs, cause they frequently foul from the water. That may be why its only running on 2 cylinders, so try changing the plugs. If its not the spark plugs then you could have done some damage from the water (hydrolock), then you are looking at lots more work.
