It probably is dirty in yours carburetor... disassembly it and clean it out... you could also do a rebuilt on the carburetor if you see the membranes worn out.
Spark plugs sometimes just dies ... it could be one spark plug.. you may be able to check it easy with a ohmmeter, i dont now by heart the ohm it should be but you can check against the other and see if one of them is too high.
Another possibility is spark cables... and the last, the coil.... but do not scare, its pretty much "sure" to be dirty in the carbs or spark plugs...
