Hi guys... thanks in advanced for your help.
I bought a VX cruiser 1100 with a complete disassembled engine.
Now its running perfectly after i changed few parts and assembled it back.
There is only one thing that keeps me wake.... When I was assembling the engine, on the oil pump there is the drive gear (6B6-13360-00-00) . One side goes inside the oil pump and turns it... the other side that is my problem! I looked everywhere and didnīt find anything showing that there was one guide pin between the driver gear and the lower crankcase. I assembled with no pin between the gear and the crankcase.... and since i bought it disassembled and missing few parts i dont know if there should be some kind of pin going inside the gear and inside the crankcase..... even on the parts diagram i didn't find, but also there is not a good view of the crankcase in this angle.
I would be glad if someone that already disassembled this engine clarify this to me !And if there is, please could you tell me the part numer ?
thanks a lot
Thanks a lot
