have you tested the compression ?, check you reed valve too ... if compression around 150 on both and reed valves ok.. check coil wiring leaking between both and also all exhaust lines if are clogged( waterlock), if too much clogged, you can clean with gasoline and shake it, will leave it very clean.
Let us know what it was ..
