Hi .. .the dash computer does not have anything to do with you misfire..
In this case you need to have a good idea about the overall situation of the engine..
you need a compression test, clean up the carbs.... check/change the spark plugs... then you try again and see what happens... there are a lot of variables that can do that in those cases of parked away jet skis for a long time....First step compression test, second clean the carbs and test/change the spark plugs... then if problem still the same, think about spark coil....
The shake probably is very bad bearing/ turbine blade bent / turbine drive shaft bent...
there are a lot to check.. there is no " one answer" for those kind of skis..
