scretweapon,
knocks are usually the transmission to the turbine.. .What happens is that the engine does not turn the crankshaft exactly the same speed all the time as a electric motor would do.. It go faster and slower depending the position of the crankshaft... If you think that inside is like a bike, you will imagine that easily. And since jet ski does not have a clutch wheel, so there is no heavy load at the end of the crankshaft to stabilize the rotational speed, so in certain way it does push faster and than slower, than faster, than slower within one rotation and that causes the connection to the turbine to knocks a little ... some jet ski have a rubber part between the turbine mount on the shaft and the crankshaft mount, and it also helps reducing the knocks but it will still have where the shaft meets the turbine.
Try to listen on youtube a video that you can hear the same engine running without the seat and compare... sometimes helps..
