Need the forum's help on this used 2002 XL!!!!! FLORIDA - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 12-30-2011, 01:23 PM   #1 (permalink)
Default Need the forum's help on this used 2002 XL!!!!! FLORIDA
Hey. New to skis in general, but I've been studying them on multiple forums the past week and learned tons about them.
But a second opinion is always helpful.
So here is the deal.
There is this 2002 Yamaha waverunner up for sale on craigslist.
yamaha xl 1200
Its a 2002 XL800, with a GP1200 engine swapped into it. The swap was done 6 months ago, and the engine has 40 hours on it. Says a race shop did the install, not himself.
He claims it does 60-70 mph.
He said everything from the GP was swapped onto his, like the cluster and guages. Would that even fit correctly on the XL800?
He says nothing is broken and I can test ride it no problem.
He is asking 2500 with double trailer and box..
2000 w/o trailer.
So what should I look for? is 2000 for just the ski decent?
By the way, everything is stock. He did mention the mechanic swapped the fuel line and put a clamp on the far cylinders oil hose.
I have a compression guage, and I have pretty good mechanical skills. Ive worked on my car a lot, and Im just starting my marine tech classes in the spring.
Thanks.
MTech305 is offline   Reply With Quote
Old 12-30-2011, 02:17 PM   #2 (permalink)
98yota's Avatar
If you are close to were the ski is, go take a look! Maybe take it for a ride, check for leaks, and function of everything.
1993 Yamaha WaveBlaster 701
1989 Yamaha WaveJammer 500
Old 12-30-2011, 02:27 PM   #3 (permalink)
Anything I should look out for?
Where should I check for leaks? When I take it for a ride, there should be no water what so ever in the hull right?
He said the carbs were rebuilt along with the motor install.
Old 12-30-2011, 02:41 PM   #4 (permalink)
98yota's Avatar
The hull should be dry, check for fluids on the inside of the hull. Make sure it doesn't have signs of a wreck or obvious neglect.
Old 12-30-2011, 02:47 PM   #5 (permalink)
How about the power valves? How can I check those for damage/wear, and to see if they even work..
Should that paint job lower the price? Not a fan of the orange..
Old 12-30-2011, 02:48 PM   #6 (permalink)
Kelley blue book has the yamaha 2002 xl 800/1200 at ~$2000 trade in value.
I know these 2 strokes need tons of maintenence, so I want to have a little wiggle room in the price in case anything happens.
Old 12-30-2011, 02:51 PM   #7 (permalink)
98yota's Avatar
Would the seller be able to throw in the trailer? That would be a good deal.
Old 12-30-2011, 02:52 PM   #8 (permalink)
And what about the cat converter? How can I tell if that is bad? Or is still even on it?
I heard a d-plate is a pain to install.
Old 12-30-2011, 02:53 PM   #9 (permalink)
Trialer and ski is $2500. W/o trailer $2000.
Im sure he will go lower than what he is asking too.
Chances are the pump needs a rebuild and the d-plate needs to be put in.
Thats an easy 500 in parts right?? Already..
Old 12-30-2011, 02:55 PM   #10 (permalink)
Is there a trim on these models?
